Turbulence model for transition
Old   August 6, 2015, 10:42
Default Turbulence model for transition
Hannes
Stormbringer505 is on a distinguished road
Hello everyone,
I am working on my master thesis which is about CFD modeling and improving a woodchip boiler's water jacket.
I've already created a mesh, mostly hex cells where heat transfer is relevant, and now I am running some simulations to determine the flow field within the water jacket as a start before I add the combustion/energy equation.
I am having trouble simulating the flow (using Ansys Fluent 15.0). On the in- and outlet pipes the Re-number is about 27.000 so this flow is fully turbulent but there are areas in the waterjacket that are going to be laminar. I can't determine exactly where they are so I can't just slice them out and add a laminar zone to them.
Some of the fluid zones are large but thin, for example 1.2 x 1.2 meters but only about 30mm thick (or 3x3 feet with a thickness of one inch in imperial). I have created five to seven cells across the thickness to keep the cell number low, it is already about five million.
Now, there's the problem: I am really not shure which turbulence model can be used in this case. I have thought about some possibilities but I want to hear the opinion of further experienced people on them:
a) Do fully laminar calculations?
I guess the results won't be very good.
b) Add a turbulence model with wall functions?
Right now I am running a simulation using the realizable k-epsilon-model with enhanced wall treatment. Only looking at the residual monitors it seems to work fine but I know that low residuals do not necessarily mean that the solution is correct. I will examine this tomorrow and let Fluent do some more iterations on it. I am running on the pressure based coupled solver with a CFL of 200 and 2nd order discretisation (1st order is unstable as I've seen so far).
In the beginning I was running on the SST k-omega-model with low Re-correction but the residuals for continuity wouldn't go below 1e-1 which is, in my opinion, not very good in this case. I've done some reading since them and I've learned that I need to set a finer mesh to resolve the boundary layer with this model, am I right?
c) Use a transition model
I haven't tried this yet and it is completely new to me. I've read that transition models also need a fine mesh to resolve the boundary layer, is that true?
I hope you guys can give me some advice. Even though I am working on a pretty powerful computer at the university calculation times are long and since literature does not simply say "use this or that model" I hope some experience might help.
Thank you!
Stormbringer505 is offline   Reply With Quote
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
