local coodinate system fluent
Old   August 5, 2015, 05:19
Default local coodinate system fluent
NNM_BSP
AP3181 is on a distinguished road
Hello all,
I'm new to Fluent and I'm struggling with the coordinate system. I defined a local coordinate system in fluent Meshing. Now I want the solver to use this local coordinate system. Is that possible?
Hope someone can help me with this
Regards
AP3181 is offline   Reply With Quote
Old   August 5, 2015, 14:20
Lucky
You can always scale/translate/rotate the mesh in Fluent so that it consistent with your coordinate system.
Old   August 6, 2015, 09:52
NNM_BSP
Thank you for your quick response LuckyTran!
Due to the geometry I defined a local cylindrical coordinate system which I want fluent to use. Makes my life much easier in writing my UDF. (My geometry has an annular shape)
have you got experience with this? tips or advies are more than welkom!
Regards
Old   August 10, 2015, 16:10
Lucky
In GUI:
Mesh=>Translate
Mesh=>Rotate
Similarly in TUI
/mesh/translate
/mesh/rotate
Repeat until you have the correct coordinate system.
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Can Fluent calculate local Nusselt # Jake Lee FLUENT 10 April 17, 2003 21:48
