periodic condition and Rotary inner domain
Old   August 5, 2015, 02:51
Default periodic condition and Rotary inner domain
Aja
aja1345 is on a distinguished road
I am simulating a turbine in Fluent and I have used periodic condition in this turbine and numerical cells in the middle part of the computational domain rotate together with the blades of the turbine. when I select "Display>view>periodic repeats>rotational>set", the whole computational domain is not created!! and the whole domain rotate in direction of other axes with selecting these options. I could create whole computational domain before applying Rotary inner domain.
Why does this happen?
Periodic boundaries are applied on the pairs of surfaces which constitute
the circumferential sides of the domain.(please see the following figure)
the turbine is as follow:
Another question: When I import msh file in fluent, some notes are Saw (please see the following figure). I want to know that these notes are for what and Are these notes related to periodic condition? these notes have not made any problem and in fact, I can set fluent and i simulate my model. but I think that rotary inner domain influence on whole computational domain, because whole computational domain is not created with applying mentioned options( "Display>view>periodic repeats>rotational>set") when I created rotary inner domain.
Thanks,
Best,
Aja
aja1345 is offline   Reply With Quote
conjugate heat transfer in a rotary condition rasekh64 FLUENT 4 June 19, 2013 04:11
[GAMBIT] Mesh of rotary valve Diana.N ANSYS Meshing & Geometry 3 April 17, 2013 06:19
rotary machine behzad bashiri CFX 2 July 17, 2012 05:23
Rotary drum attached with baffles nutow CFX 11 November 12, 2010 15:36
Modeling of airfoil rotary motion Agni FLUENT 0 November 24, 2008 04:43
