Fluent Jornal File
Old   July 23, 2015, 03:44
Default Fluent Jornal File
Nikini Gamage
npuh002 is on a distinguished road
Hi Guys,
I am trying to run a 2 way FSI simulation using the command window. I need to run it via the command window as I will need to run it on a HPC system in the future.
I have created the .dat file from the structural system, the .cas file on the using the fluent system and the .sci from the system coupling system.
I also need a fluent journal file that is needed to run Fluent in batch, read the .cas file and solve it. I used a journal file that was given in an example, which is as follows:
file/start-transcript "Solution 2.trn"
file set-batch-options , yes ,
file/read-case/fluidFlow.cas
solve/initialize/initialize-flow
(sc-solve)
wcd FluentRestart.cas.gz
exit
ok
However when I try to run this on command window it does not appear to do anything. The fluent command window finishes executing but the other two for (structural and system coupling) are still running.
I am think it is because of the journal file that I have used. Does anyone know how to write a journal file like this or where I could get any help.
Any help in this matter would be greatly appreciated.
Cheers,
Nikini Gamage
PhD Student
Auckland Bioengineering Institute
The University of Auckland
npuh002 is offline   Reply With Quote
Old   December 2, 2015, 21:41
Default Hpc
cStef is on a distinguished road
Hi!
Have you figured out how to run the 2-way-fsi on the HPC? Because I am also having this problem...
Best regards,
Conny
cStef is offline   Reply With Quote
command editor, fluent, hpc, journal
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
