What Radiation Model should I use?
Old   July 20, 2015, 23:05
Default What Radiation Model should I use?
RJC
redwanamit034 is on a distinguished road
I am doing a conjugate heat transfer analysis between a solid body and a high velocity gas (helium) flowing over the solid. The solid is heated by a heat source and it is cooled down by the fluid. I am only concerned about the temperature distribution in the solid.What radiation model should I use?
redwanamit034 is offline   Reply With Quote
Old   July 20, 2015, 23:14
RJC
Any idea anyone???
Old   July 21, 2015, 00:09
RJC
Any suggestion? DO, S2S or P1 - which one should I use?
Old   July 22, 2015, 05:30
P.
Peter_J is on a distinguished road
Send a message via Skype™ to Peter_J
You have provided very little information about the key issue: heat source. How this heat source is located / attached in your model? Are you solving localized heat source in proximity to some plate being heated and then cooled by gas?
Could you post some very simple picture of your case?
Peter_J is offline   Reply With Quote
conjugate heat transfer, radiation models
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 4, 2013 00:04
problem in glass radiation model (DO model) wunan805 FLUENT 0 October 10, 2012 06:06
Help: Radiation model MANOJKUMAR FLUENT 4 November 24, 2005 03:45
definition difficulty-->DO radiation model Harry Qiu FLUENT 0 March 29, 2001 10:19
