What are the internal numerical data types used by FLUENT? |
July 16, 2015, 08:18 |
V.Leb
Rep Power: 11 |
Hi everyone,
I was wondering what is the default numerical data type FLUENT is using. In the manual I can find this:Lhttp://www.afs.enea.it/project/neptunius/docs/fluent/html/udf/node252.htm but it's for UDFs. The reason I'm asking is because I wonder if running a simulation on a mesh that has micro meter scale system expressed in meters (i.e. length scale etc. units are read as meters in FLUENT) would be worse/not converge as fast as one using micro meter scale in FLUENT (i.e. instead of having 0.000001m I would have 1um when FLUENT is calculating). I guess if FLUENT is using at least float precision, then this wouldn't be a problem... Cheers |
July 16, 2015, 13:08 |
Andrew Kokemoor
Rep Power: 14 |
The default is single (float) precision, but double is supported and easy to enable. In the GUI launcher, there's a checkbox for it. If you're launching from command line, add "dp" to the solver flag, e.g. -3ddp instead of -3d.
July 21, 2015, 12:15 |
V.Leb
Rep Power: 11 |
Thanks, I realised that after I have posted the question. I'm a bit surprised that it makes a difference in convergence ( I thought floats "dynamic range" would be more than enough...).
fluent 12.0, scale factor, units |
high continuity Fluent modeling ABL with WRF/CALMET data | xitao21 | FLUENT | 1 | May 2, 2019 11:20 |
OpenFoam to Fluent data conversion Problem | vemps | OpenFOAM | 1 | August 8, 2011 03:30 |
How to read tabulated data in Fluent | Siddhartha Pal | FLUENT | 0 | August 30, 2007 06:18 |
reading data into fluent | co2 | FLUENT | 0 | December 28, 2003 02:31 |
Boundary Types in Fluent 5/6 | Oresko | FLUENT | 3 | July 23, 2002 20:23 |
