Transient timestep question
Old   July 13, 2015, 18:53
Default Transient timestep question
AZ1621 is on a distinguished road
I am running a transient turbulent flow simulation of a bluff body in a wind tunnel. I am trying to validate experimental data with my results. To get my residuals down to the appropriate level I have to use an extremely small time step (1 e-5 seconds). I am trying to model and time average the flow properties surrounding the vortex shedding occurring in my simulation but using the time-step of 1e-5 it would take a huge amount of time-steps to gather data for ten or twelve shedding cycles due to the startup time for the shedding to begin occurring from the moment the simulation begins. I thought to use a larger time step to achieve a flow time where I know shedding is occurring but I don't converge above the 1e-5 second timestep setting. Can I still use larger timesteps to advance? Or is there a better way to go about this?
Thanks for the help!
AZ1621 is offline   Reply With Quote
Old   July 15, 2015, 12:45
Lucky
You really only need a small enough time-step to temporally resolve the time-scale you are interested in (the shedding frequency I guess). This can be done with as few as 10 time-steps per event. You should compare the 1e-05 to the time-scale of the shedding frequency.
But of course it is important to make sure that the time-steps are converged.
Old   July 15, 2015, 16:00
Thanks for the reply,
Last night I simulated 500 iterations at 0.01(s) timestep. I observed the vortex shedding had a period of about 10 timesteps or 0.1(s) so the shedding frequency is about 10Hz. Now all the residuals on those iterations ran for the full 20 inner iterations and only got down to about 1e-2. So running a single shedding period at 1e-5(s) timesteps would take about 10,000 iterations. I want to time average the shedding so I will need 8-10 cycles. This ups my iterations to about 80,000-90,000. This would take an enormous amount of time to simulate even if the iterations converge every 8 inner iterations. Could be an issue to do because my licence resets every 4 hours. Any thoughts on how to reduce increase the timestep while still retaining convergence?
Only super concerned with using the very small timestep because at a timestep of 0.01(s) i was seeing about a 18.75% difference in the mean values when compared with experimental data.
transient, turbulent
Transient or Transient Blade Row? liucheng8602 CFX 2 June 19, 2014 08:03
transient timestep tony CFX 1 March 12, 2008 17:39
Time value of timestep in Transient simulations siv CFX 3 December 8, 2005 12:15
Timestep for transient simulation houman CFX 2 April 28, 2005 04:44
timestep duration-a question Shankar FLUENT 2 August 15, 2002 13:12
