July 10, 2015, 06:18 |
Decreasing the memory RAM usage of Fluent
Rep Power: 12 |
Hello to all,
I have i7 2600 CPU with 8 cores. I want to run two cases (each one using 4 cores), because I notice that running with 4 cores just increase simulation time about 20% in comparison with using the all 8 cores. Therefore, it would be faster to run 2 simulations with 4 cores at the same time than 2 sequential simulations using 8 cores. However, we i try to run two simulations with 4 cores, the PC crashes which i believe its due to the lower memory RAM, 8 GB. I tried to run fluent from the cmd line without the GUI, but i didn't find any decrease in memory usage. Does any one have some suggestions for decreasing the memory RAM usage of Fluent? Thks! |
FLUENT mesh dependent memory requirements? | CDollarsign | FLUENT | 3 | April 4, 2013 15:27 |
RAM memory problem | alpha | Main CFD Forum | 8 | February 12, 2008 12:07 |
memory (RAM) question | matt | FLUENT | 7 | November 28, 2006 04:30 |
fluent 32 bit maximum RAM | Mike | FLUENT | 2 | August 19, 2006 10:45 |
CFX CPU time & real time | Nick Strantzias | CFX | 8 | July 23, 2006 18:50 |
