July 8, 2015, 11:23 |
error in parallel processing
karim
Rep Power: 11 |
i have project that boundary condition change with time(udf) and calculation in 2 processor machine and in parallel is good but in 4 processor machine have below error
please help me thank you ================================================== ============================ Node 2: Process 748: Received signal SIGSEGV. ================================================== ============================ unable to read the cmd header on the pmi context, Error = -1 . Error posting readv, An existing connection was forcibly closed by the remote host.(10054) unable to read the cmd header on the pmi context, Error = -1 . Error posting readv, An existing connection was forcibly closed by the remote host.(10054) unable to read the cmd header on the pmi context, Error = -1 . Error posting readv, An existing connection was forcibly closed by the remote host.(10054) The fl process could not be started. unable to read the cmd header on the pmi context, Error = -1 . Error posting readv, An existing connection was forcibly closed by the remote host.(10054) received suspend command for a pmi context that doesn't exist: unmatched id = 3 |
December 15, 2015, 01:13 |
#2 | |
abed
Rep Power: 12 |
Have you solved your problem? Actually I have the same problem as yours. If you find the solution, would you please tell me? Thanks. toghaya@gmail.com |
error, parallel, signal sigsegv, udf |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
problem for parallel processing | minaret | OpenFOAM Running, Solving & CFD | 14 | January 20, 2015 00:41 |
OF Parallel Processing with Core i7 - How to Handle Hyperthreading | dancfd | OpenFOAM Running, Solving & CFD | 5 | March 5, 2012 22:43 |
HP MPI warning...Distributed parallel processing | Peter | CFX | 10 | May 14, 2011 07:17 |
About parallel processing in Linux | tuks | CFX | 10 | August 8, 2005 09:22 |
