July 8, 2015, 10:04 |
error in parallel processing
karim
Rep Power: 11 |
i have project that boundary condition change with time(udf) and calculation in 2 processor machine and in parallel is good but in 4 processor machine have below error
please help me thank you ================================================== ============================ Node 2: Process 748: Received signal SIGSEGV. ================================================== ============================ unable to read the cmd header on the pmi context, Error = -1 . Error posting readv, An existing connection was forcibly closed by the remote host.(10054) unable to read the cmd header on the pmi context, Error = -1 . Error posting readv, An existing connection was forcibly closed by the remote host.(10054) unable to read the cmd header on the pmi context, Error = -1 . Error posting readv, An existing connection was forcibly closed by the remote host.(10054) The fl process could not be started. unable to read the cmd header on the pmi context, Error = -1 . Error posting readv, An existing connection was forcibly closed by the remote host.(10054) received suspend command for a pmi context that doesn't exist: unmatched id = 3 |
error, parallel, signal sigsegv, udf |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
problem for parallel processing | minaret | OpenFOAM Running, Solving & CFD | 14 | January 20, 2015 00:41 |
multiphase solver - parallel processing - GAMG | thibault_pringuey | OpenFOAM Programming & Development | 2 | August 27, 2013 23:03 |
HP MPI warning...Distributed parallel processing | Peter | CFX | 10 | May 14, 2011 07:17 |
About parallel processing in Linux | tuks | CFX | 10 | August 8, 2005 09:22 |
