July 7, 2015, 22:31 |
Flow over an Airfoil
Christopher
Rep Power: 11 |
I been trying to simulate the flow over E193 airfoil, and I get a Cl that resembles lab data. The drag coefficient doesn't come anywhere close to the data I am looking for. I am guessing it is an issue with the monitor, but I am not sure.
Also, I was wondering what data forces should I export from FLUENT to calculate the drag coefficient myself. Thanks in advance! |
July 8, 2015, 08:38 |
Rep Power: 11 |
you should check your reference values you put; especially the "length" for 2D airfoil, it should be the chord. check also the density and the velocity.
July 8, 2015, 11:25 |
Christopher
Rep Power: 11 |
Okay. I changed the reference values to the length of the airfoil and adjusted the velocity to what I had put in for the inlet. I actually got better number now, but the numbers are still too small to be compared to the published data. Would it be that I took the wrong measurement of one of the values?
July 8, 2015, 12:04 |
Rep Power: 11 |
what about the density ? did you put the right density in the reference values, the one you used as pressure outlet conditions?
July 8, 2015, 15:47 |
Christopher
Rep Power: 11 |
I kept the density the same as the fluid material. Was there something I had to specifically define in the boundary condition for outlet pressure?
July 9, 2015, 02:10 |
Ali
Rep Power: 16 |
Post your results and simulation setup.
Best Regards Ali |
July 10, 2015, 22:32 |
Christopher
Rep Power: 11 |
For Cl I get -0.00236 and for Cd I get 0.1936. For zero angle of attack, I was expecting for Cl to be closer to 0.3.
The setup: Model - Standard k-e, Standard, Wall Fn Inlet Velocity - 2.88 Reference Values http://i62.tinypic.com/qy9to1.png The airfoil is 3D with a cord length of 0.3048 m with an extrusion of 0.3048 m. Solution Method is simple with second order upwind set for turbulent kinetic energy, momentum and turbulent dissipation rate. Solution controls are defaults and so are the monitors for Cd and Cl. If you need anymore information, I can provide it. Thanks for the help. |
July 12, 2015, 16:12 |
Ali
Rep Power: 16 |
Airfoil is symmetric? The simulation setup looks perfect.
Best Regards Ali |
July 12, 2015, 17:16 |
#9 |
Christopher
Rep Power: 11 |
Yep. It's this extruded by the mentioned distance.
http://recumbents.com/wisil/hpb/prop/e193.gif |
July 13, 2015, 00:39 |
#10 |
Ali
Rep Power: 16 |
Send me fluent case file...
Best Regards Ali |
July 13, 2015, 16:18 |
#11 |
Ali
Rep Power: 16 |
Any success?
Best Regards Ali |
July 13, 2015, 19:12 |
#12 |
Christopher
Rep Power: 11 |
I am getting better numbers. If I kept the enclosure the same size, I get values that are only 30% off. Then if I increase the enclosure, the numbers got smaller.
What you suggested did help a lot, I am not getting close enough values within like 10-15%. :/ |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
flow over an airfoil 3d ( Geometry on icem cfd ) | dfmona | Main CFD Forum | 0 | April 14, 2010 00:32 |
problem in modeling flow over a 3d airfoil | guess | Main CFD Forum | 8 | March 20, 2010 14:54 |
Airfoil conditions for unsteady flow | Dave | Main CFD Forum | 3 | April 24, 2008 18:11 |
Simulating flow past airfoil with different AOA | Quarkz | Main CFD Forum | 2 | January 6, 2006 11:56 |
