Auto Shutdown the pc after completion of run. |
July 7, 2015, 02:23 |
Bhanuday Sharma
Rep Power: 11 |
Hi everybody. Is there any way to shutdown the PC itself after completion of solution run.
I want to give run to the PC in the night before sleep. So that I can sleep and check the results in the morning. (FLUENT) Can we do it by writing a journal file? |
July 7, 2015, 04:03 |
Maxime Perelli
Rep Power: 41 |
execute your calculations with batch.
https://www.sharcnet.ca/Software/Flu...ode21.htm#5442 Last line of your batch will content the shutdown command (depends on your os)
In memory of my friend Hervé: CFD engineer & freerider |
July 8, 2015, 03:42 |
Bhanuday Sharma
Rep Power: 11 |
Thanks dear for your reply.
But I find the solution by using the Journal file. as follwoing;- /solve/initialize/hyb-initialization/ wcd file.cas solve/iterate 500 wcd file1.cas !shutdown /s |
journal file, shutdown |
Cannot run phoenix on linux opensuse 13.1 kde | mabal | Phoenics | 0 | June 15, 2014 07:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 12:20 |
error 262144 and unexpected disconnect when run on 2 nodes | Emily1412 | SU2 Installation | 1 | April 10, 2014 18:08 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 13:08 |
Help-Edit Run in Progress | BalanceChen | CFX | 0 | March 30, 2011 10:23 |
