udf parallel
Old   June 29, 2015, 06:05
Red face udf parallel
abed
toghay is on a distinguished road
Hi
I use a simple udf to simulate a dynamics mesh problem. in my udf I write some data to a txt file. when I use a serial processing no problem occurs.but when I use parallel processing (for example 4 core) in each time step the udf run 4 times then data write 4 times to txt file.
I see the forums about this problem and "Paralleling Serial UDF" but I don't understand how paralleling every serial udf.
I cant use "#if !RP_HOST" command properly.
Thanks
toghay is offline   Reply With Quote
Old   July 1, 2015, 04:08
abed
No one can help me!!
Old   July 14, 2015, 00:13
Abazar
Abazar is on a distinguished road
Hi
This is my problem too
I have to define a parallel UDF for a fully developed velocity inlet to rectangular inlet
Abazar is offline   Reply With Quote
"Define_Profile" UDF for parallel solver Antoine Fluent UDF and Scheme Programming 9 February 29, 2016 07:09
Problem in using UDF in parallel computing Yogini Fluent UDF and Scheme Programming 0 January 22, 2013 09:23
UDF Error with Parallel affter several step trantoan2008 Fluent UDF and Scheme Programming 0 January 7, 2013 08:33
Parallel UDF Error Andrew FLUENT 2 March 30, 2007 12:11
UDF in parallel version. yobee FLUENT 0 August 17, 2004 05:12
