Fluent rp var to modify rotation speed of a boundary |
June 26, 2015, 14:17 |
Dear forum users,
I'm working on a rotating geometry in ansys fluent , under the section: Define/Boundary condition/Wall --> set to moving wall with rotational mode checked this gives access to a constant rotation speed. the goal is to achieve variable rotation speed: 1/ Decomposing the rotation speed into a Vx and Vy components varying with time Or 2/ use the specefic rp-var (if possible) that can access and modify the rotation speed value, and pass the desired value to the solver. it would be very helpful to me to know what rp-var manipulātes the rotation speed of a moving wall. and definitely the rp-vars for the rotation axis orientation coordinates would be helpful too here is the panel: http://s23.postimg.org/70zlk9y8b/rp_var.jpg thanks in advance |
July 11, 2015, 00:10 |
Could someone please possibly point out the rp-var associated with rotation speed (rad/s) ? thanks again
August 12, 2015, 16:58 |
update
Problem solved. thanks anyway
moving wall, rotation speed, rp variable |
LSR (Land speed record) car simulation on FLUENT | Maxime31850 | FLUENT | 2 | May 1, 2013 12:15 |
FLUENT boundary condition problem with gmsh | EIvb | FLUENT | 0 | April 30, 2013 08:45 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 05:13 |
asking for Boundary condition in FLUENT | Destry | FLUENT | 0 | July 27, 2010 01:55 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
