Variable against theta (degree) from 3D cylinder |
June 23, 2015, 12:58 |
Ontario
Rep Power: 11 |
I am trying to get the results of heat transfer vs. theta for a specific section of a 3D cylinder using Fluent. I've attached two pictures, the first one is of the cylinder itself and the 2nd one is with a plane intersecting where I want to see the results of heat transfer vs. theta around the cylinder surface. Thanks. |
3 dimensional simulation, cylinder domain, fluent 13, theta component |
How to plot Cp vs. Theta on a 3d Cylinder | nsiderbam | FLUENT | 10 | March 4, 2019 14:55 |
flow around a circular cylinder with velocity inlet and outflow outlet | shuoxue | OpenFOAM | 1 | March 3, 2014 10:42 |
plot (local nusslet number/modified rayleigh) v/s theta around a cylinder in fluent | me_geo | Fluent UDF and Scheme Programming | 0 | September 18, 2013 02:43 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
