Reverse Flow Pressure-Outlet
Old   June 23, 2015, 07:39
Default Reverse Flow Pressure-Outlet
Gustavo
gustavosimiema is on a distinguished road
I have seen in lot´s of Posts the Suggestion to extent the outlet. But actually, I don´t know what does it means and neither how to do it. Could anyone give me a hint about this?
I´m working with a laminar model. Mixture of O2 and N2. Species Transport on and Energy Equation on. The Problem consist of a gasfeed inside a chamber. So I have an inlet (5mm) to fill in gas in the gasfeed, than I have an outlet (2mm) from this gasfeed to fill in the chamber, and then I have the outlet (260mm) in the middle-top of the chamber.
I´m using mass flow inlet (1e-5 kg/s) and pressure outlet in both outlets (1Pa).
I don´t know what is causing this reverse flow. Anyone has a hint?
thanks in advance
gustavosimiema is offline   Reply With Quote
Old   June 23, 2015, 08:41
pakk will become famous soon enough
"extent the outlet" = make the outlet longer.
So add some volume behind the outlet.
pakk is offline   Reply With Quote
Old   June 23, 2015, 08:59
Gustavo
Thank you so much for your reply. But I´m still facing reverse flow
Old   June 23, 2015, 09:01
Wait a minute... Do you mean you have reversed flow during the simulation, or do you have reversed flow in the final converged solution?
Old   June 23, 2015, 09:05
Gustavo
I have reversed flow durind the Simulation and also when the solution is converged...
Old   June 23, 2015, 09:09
OK, ignore the reversed flow during the simulation, but only focus on the one in the converged solution.
If you want to know where the reversed flow comes from: just look at the result! Look at how the flow lines go, and try to understand why you have reversed flow.
That is the best hint I can give: look at you solution... It is not much, but I can do no better...
Old   June 23, 2015, 09:14
Gustavo
I will do that.
I don´t know the relationship, but when I set the operating conditions to 0Pa in the pressure I´m not able to run the Simulation because I have Problems with mass diffusivity. When I Keep the Default pressure I can run the Simulation but reversed flow appears. Do you know something about that?
once more thank you for your time
Old   June 23, 2015, 09:18
But those are two physically different problems that you are simulating.
If you set the operating pressure to atmospheric pressure, your outlet pressure is 101325 Pa + 1 Pa = 101326 Pa.
If you set the operating pressure to 0 Pa, your outlet pressure is 0 Pa + 1 Pa = 1 Pa.
So if you change operating pressure, you change your simulation physically!
Old   June 23, 2015, 09:28
Gustavo
My objective is to Keep the pressure inside the chamber around 1Pa.
Making the operating pressure as 101325 Pa I could see in the countours of pressure that I achieved this objective. The pressure inside the chamber after results converged was 1Pa. So in my understanding, based on this Point of view I´m in a good way. I just Need to understand why I´m having reversed flow.
I think my geometry is not properly defined. I have a pipe with 30mm Diameter and 1060 mm lenght inside a cubic chamber (1060x1060x1060mm). I created an inlet to provide gas for the pipe. Than I create an outlet in this pipe to provide gas inside the chamber. Than I have the outlet to remove gas from the chamber. Is this construction ok? Or do you think I Need to Change something?
I´m afraid this is the origin of my Problems.
thank you so much
Old   June 23, 2015, 09:48
Absolute pressure of 1 Pa or gauge pressure of 1 Pa? That is a very big difference, but you don't make clear which one you mean.
I don't understand your question. If that is your geometry, then that is your geometry. You can change your geometry, but then you are solving a different problem. What is it that you want to learn from the simulation?
Old   June 23, 2015, 10:02
Gustavo
I mean the gauge pressure 1 Pa. (This is a low-pressure Simulation)
With this Simulation I would like to see the pressure difference between the pipe and the chamber. And also the behaviour of the gas from the inlet until the outlet of the chamber.
Old   June 23, 2015, 10:08
This is confusing.
Total pressure = 1 Pa: low-pressure simulation, close to vacuum.
Gauge pressure = 1 Pa: a normal-pressure simulation, close to atmospheric.
Old   June 23, 2015, 10:10
Gustavo
Sorry... I´m not so familiar with this concepts. I´m new in fluent. So, I mean Total Pressure = 1Pa (to have a low pressure condition)
Old   June 23, 2015, 10:19
What you can do is set operating pressure at 1 Pa, and set your boundary condition to 0 Pa.
(BTW: this is all probably unrelated to your reversed flow. If you want to know why you have reversed flow, look at the solution!)
Old   June 23, 2015, 10:32
Gustavo
Thank you so much...
In my result, I didn´t got a streamline from the inlet of the pipe until the outlet of the chamber. I don´t know if it is related to the reversed flow...
Old   June 23, 2015, 10:40
Then where do the streamlines from the inlet end?
Old   June 23, 2015, 10:42
Gustavo
The end is on the top of the pipe.
The inlet is in z direction and the top of the pipe is in the plane xy. So the inlet is perpendicular to the face of the pipe.
Old   June 23, 2015, 10:47
So you have streamlines that start at the inlet and end at a wall?
Old   June 23, 2015, 10:52
Gustavo
Exactly...
Old   June 23, 2015, 10:56
Then it is hard to believe that you have a converged solution. Check your mass flow balance. (Reports->Fluxes, Mass Flow Rate and select all boundaries)
reverse flow
Pressure outlet as a function of the flow rate (windkessel) Trev0r CFX 10 October 23, 2023 17:50
Solution is converging but have reverse flow on pressure outlet Dinesh_Dhande Main CFD Forum 2 March 11, 2018 02:02
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
