Reverse Flow Pressure-Outlet
Old   June 23, 2015, 11:00
Gustavo
gustavosimiema is on a distinguished road
I think Itīs ok, please see the results:
Mass Flow Rate (kg/s)
inlet 1.71e-05
interior-fluid 0.00012537814
outlet_chamber -1.0750113e-05
outlet_gasfeed -7.0932714e-06
wall-fluid -0
Net -7.4338468e-07
gustavosimiema is offline   Reply With Quote
Old   June 23, 2015, 11:09
pakk will become famous soon enough
That does not seem so wrong, although the big number after the interior is a red flag.
But then how can you see all streamlines from the inlet ending up at walls? What happens if you do reverse streamlines from the outlets?
pakk is offline   Reply With Quote
Old   June 23, 2015, 11:13
Gustavo
Basically I have to choose the Region, for example I can set the streamline from the outletgasfeed backwards. Than it will Show just streamlines inside the gasfeed. Or I can set the streamlines from the outlet of the chamber backwards. Then I will see lotīs of vortex inside the chamber. And for me, it sounds strange, there is no sense to have vortex in this case.
Old   June 23, 2015, 11:18
And your residuals are really low enough?
Old   June 23, 2015, 11:23
Gustavo
Are lower than 1e-3 but I also tested with more iterations and the residuals stabilized...
The inlet is on the bottom of the gasfeed...
Old   June 23, 2015, 11:28
I am sorry but I don't understand the geometry. Where is your inlet? Where are your two outlets? How can flow go from the pipe to the chamber?
Old   June 23, 2015, 11:35
Gustavo
The gas goes into the gasfeed (pipe) from the inlet. Then the gas get out from the pipe and gent into the chamber through the gasfeed outlet and then the gas come out the chamber through the outlet of the chamber.
Itīs more clear?
Old   June 23, 2015, 11:41
Aha, here is your problem:
No, that is not what an outlet does. If you use an outlet, the gas will go out of your simulation. Not into the chamber...
You said that the streamlines from the input goes to the "top of the pipe". If I look at your picture, that is where you placed the "outlet of the gas feed", so streamlines go from inlet to outlet, as it should.
You should not have those "outlets of the gas feeds" as boundaries. You should just have them as holes in the wall.
Old   June 23, 2015, 11:43
Gustavo
Wow NICE
But how can I tell to fluent that there are holes?
Old   June 23, 2015, 11:46
In the same way you told Fluent there was a pipe: Draw them in your design.
Old   June 23, 2015, 11:54
Gustavo
Thank you so much...
I have just started a new Simulation without the boundary gasfeed-outlet. So now I have just the inlet of the gasfeed, the holes and the outlet of the chamber.
The reversed flow persists... letīs see in the end how it would be.
thank you so much...
Iīll let you know when it is finished.
Old   June 23, 2015, 12:10
Gustavo
I think didnīt worked...
the streamlines didnīt achieve the outlet. In this case, after convergence I got reversed flow in 37 faces in pressure outlet.
Any idea?
Old   June 23, 2015, 12:19
Simulate longer. The standard 1e-3 residual is too high for these cases.
Old   June 23, 2015, 12:26
Gustavo
Ok...
Now I put 1e-6 and 5000 iterations. Letīs see ...
I let you know when it finishes. Now it will take time...
Old   June 24, 2015, 06:42
Gustavo
The solution converged after 1256n iterations with residual 1e-6. The reversed flow message disappeared. But when I activate the streamlines I still see lots of vortex inside the chamber before the gas flow to the outlet. Do you have any hint?
Now I have just tried to put operating condition as (1Pa) and the boundary condition as (0Pa) keeping all other Parameters the same but in this way the Mass Diffusivity error appeared. When I initialize the Simulation the Z velocity is 700 m/s and the temperature 7K (this is so strange for me).
What would you suggest for me to do in both cases?
reverse flow
Pressure outlet as a function of the flow rate (windkessel) Trev0r CFX 10 October 23, 2023 17:50
Solution is converging but have reverse flow on pressure outlet Dinesh_Dhande Main CFD Forum 2 March 11, 2018 02:02
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
