Multiple BC error
Old   June 21, 2015, 09:27
Default Multiple BC error
Praveen
KPraveen is on a distinguished road
I am solving for a 3D jet in cross flow problem. I used the velocity inlet BC for the inlet and outflow BC for outlet.
But I get this warning:
Both outflow and pressure boundaries are present in the domain. This is an incompatibility and solution cannot proceed until this is fixed.
Also there is divergence detected in AMG solver for temperature, xyz momentum and pressure correction.
Please help.
KPraveen is offline   Reply With Quote
Old   June 22, 2015, 04:58
pakk will become famous soon enough
Please help.
Are you sure you don't have a pressure outlet/pressure inlet somewhere? Your error message suggests that you do.
pakk is offline   Reply With Quote
Old   June 22, 2015, 05:01
Praveen
Yes, I used the pressure inlet condition on one inlet. I have two inlets and one outlet in this problem.
Old   June 22, 2015, 05:20
So then the error is clear, not? You can not have a pressure inlet and "outflow" boundary at the same time.
So the solution is also clear, not? Change the pressure inlet to mass-flow inlet, or change the outflow to pressure outlet.
Old   June 22, 2015, 05:38
Praveen
I changed the outflow to pressure outlet BC . But still I am getting divergencce in AMG solver
Old   June 22, 2015, 05:45
Then this is the point where you play around with numeric settings to get a convergent simulation. Use a different initialization, change underrelaxation factors, use different solver schemes, different discretizations...
If you have no feeling for it, then just play around, the only way to get experience is by trying things.
Unfortunately there is no "general" method that always work, otherwise everybody could do CFD.
Old   June 22, 2015, 05:51
Praveen
I will try pakk...........thanks .......
divergence amg, divergence detected, warning message
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
