June 21, 2015, 05:16 |
Problem with boussinesq!
Hi
I am trying to simulate the heat transfer from hot water to PCM ( phase change material) in a double pipe heat exchanger.(It makes PCM to melt) I modeled the problem in 2D at inlet of exchanger where the inner tube has constant tempreture and outer tube is adiabatic. Because of phase changing in PCM,the density is not constant and the bouyancy is important;so I should use Bossinesq as density. But the problem is when I model density constant, it is normal, but when I use bossinesq it is extraorinary in comparison with my source. I attached my answers and also the source paper. Please help me as soon as possible to find out what is the problem? Thanks |
boussinesq model |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 08:27 |
Density boussinesq Problem | matrix-1.0 | FLUENT | 9 | January 17, 2014 22:17 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 09:39 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
