calculationg heat transfer coefficient in a packe bed |
June 17, 2015, 06:55 |
sarah
Rep Power: 16 |
I am supposed to simulate heat transfer in a packed bed of fuel spheres. I use FLUENT 14.5. in literature, Heat transfer coefficient is about 20000, but in Fluent , Wall function heat trans coef , it is 300. I know, I should use the following formula to calculate HTC: h = heat_flux / (T(z) - Tbulk(z)) but there is a problem related to heat flux; I don't know how to find it in fluent. should I go the following path to find heat flux? report>fluxes>heat transfer rate> inlet-outlet Thank you |
June 18, 2015, 06:56 |
liusuanyatong
Rep Power: 11 |
I think you are right.But I'm not sure.I have some question about heat flux.
June 18, 2015, 14:24 |
shirin patil
Then how will find the heat flux for constant wall temperature to find the nusselt number
June 18, 2015, 15:17 |
sarah
Rep Power: 16 |
it will work for constant wall temp, and after you calculate heat flux you can obtain Nu simply by using following eq:
Nu= ( heat_flux/T-T_wall) *L/K_fluid |
Heat flux and Heat transfer coefficient | sakil2k3 | FLUENT | 4 | July 5, 2015 16:07 |
Heat Transfer Coefficient | AndBra | FLUENT | 2 | June 4, 2013 16:35 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 16:35 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Heat Transfer Coefficient | los | OpenFOAM Running, Solving & CFD | 5 | January 31, 2010 18:44 |
