[REQUEST HELP] Fluent 15.0 using NIST real gas model
Old   June 16, 2015, 12:00
Default [REQUEST HELP] Fluent 15.0 using NIST real gas model
Xavier
Reivax is on a distinguished road
I'm encountering a problem in my simulation while using the NIST real gas model in Fluent 15.0. I'm trying to simulate a flow in a cooling channel using the following model :
  • COOLANT
    liquid hydrogen from the NIST database
    velocity: 40 m/s
    Pressure: 26 MPa
    Temperature: 52.4K
  • TEMPERATURE OF THE WALLS
    Inner Wall: 270K (constant)
    Outer Wall: 700K (constant)
    Side Wall: I use an udf to make a linear variation of the temperature from one edge to the other
    #include "udf.h"
    DEFINE_PROFILE (gradient_temp1,t,i)
    	real x[ND_ND];
    	real y;
    	face_t f;
    	begin_f_loop (f,t)
    			F_CENTROID(x,f,t);
    			y = x[0];
    			F_PROFILE(f,t,i) = -156193.2437*y - 7572.6189;
    	end_f_loop (f,t)
    DEFINE_PROFILE (gradient_temp2,t,i)
    	real x[ND_ND];
    	real u;
    	face_t f;
    	begin_f_loop (f,t)
    			F_CENTROID(x,f,t);
    			u = sqrt(x[0]*x[0]+x[1]*x[1]);
    			F_PROFILE(f,t,i) = 156193.2437*u - 7572.6189;
    	end_f_loop (f,t)
    DEFINE_PROFILE (gradient_temp3,t,i)
    	real x[ND_ND];
    	real v;
    	face_t f;
    	begin_f_loop (f,t)
    			F_CENTROID(x,f,t);
    			v = x[0];
    			F_PROFILE(f,t,i) = 156193.2437341082*v - 7572.6189;
    	end_f_loop (f,t)
My problem is that when I try to run the calculation it crashes after a few iterations, returning theses messages in the console :
I've run another simulation without any problem using the NIST database but with a constant temperature of 500K for every wall. But this one keep crashing, does anyone has a clue on what might be the problem here ?
If you need more information to solve my problem, please ask.
Reivax is offline   Reply With Quote
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Peng Robinson Real Gas Model cfd seeker CFX 1 September 30, 2013 19:20
Weighted Sum of Gray Gas Model (WSGGM) in FLUENT anthony05 Fluent UDF and Scheme Programming 0 July 15, 2013 01:07
Question about Real gas model for refrigerant in Fluent ddqp FLUENT 0 March 21, 2011 22:38
