Very low coefficient of Lift for a 2D airfoil (Ansys) |
Aidan
Rep Power: 11 ![]() |
I am using Ansys Fluent to investigate the coefficient of lift for a 2D airfoil for my university thesis. I am very new to Ansys and have followed a number of tutorials online to produce my model. My initial work involves a mesh convergence study, so I have created a number of models with varying meshes containing between 30,000 and 200,000. Unfortunately, when I run the Ansys Fluent programme to date, I obtain a Cl of approximately 0.45, when the angle of attack is 8 degrees (some of my bigger programmes are still running with over 80,000 iterations). Previous experiments and simulations by others, using similar conditions have achieved Cl values of approximately 0.65 (http://turbmodels.larc.nasa.gov/naca0012_val.html). Furthermore, the previous simulations seem to have achieved this for domains containing between 60,000 and 80,000 nodes. I am no where near this. Would anyone be able to provide me with any indication why this would be, and how I may resolve it? (The following are the steps and conditions I have used to date: - created the geometry in Ansys Geometry, imported to Ansys ICEM. - The computational domain is similar to this: http://turbmodels.larc.nasa.gov/naca0012_val.html, except I used 50 chord lengths instead of 500. - I used the following boundary conditions: Velocity Inlet, Pressure Outlet, and symmetry at the upper and lower boundaries. - Exported the model to Ansys Fluent. - In the "Models" tab, I used Realizable k-e model, with standard wall functions. - Calculating Cl for an angle of attack of 8 degrees, a chord length of 1m, Reynolds number of 6 million. Therefore, in the "Boundary Conditions" tab, I used velocity magnitude 87.64 m/s, x-direction flow direction (cos alpha)=.9903 and y-direction flow direction (sin alpha) = 0.1391 - In "Reference Values" tab, I used area = 1 (m2), density of air=1.225 (kg/m3), and viscosity 1.7894e-5 (kg/m-s), temp 288.16K - "Solution Methods" tab: Simple, and the remainder default. - "Monitors" tab: Convergence of all residuals at 1e-6 - "Monitors" tab: Cd-1: Force Vector X = 0.9903, Force Vector Y = 0.1391 - "Monitors" tab: Cl-1: Force Vector X = -0.1391, Force Vector Y = 0.9903 - "Solution Initialisation" tab: Compute from Inlet -> Initialise - Run Calculation) Apologies about such a long email. I would very much appreciate any help I can have on this, as I have been trying to figure it out for over 2 weeks and seem to be getting no where. Thanks, Regards, Aidan Last edited by aptahaney; June 16, 2015 at 11:23. |
Aidan
typo in original above: "I obtain a Cl of approximately 0.55" should have said "0.45" - corrected now
ansys fluent 15, coefficient of lift |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Lift and drag coefficient with strange values for NACA airfoil | antonio_ing | OpenFOAM Running, Solving & CFD | 16 | September 13, 2012 12:21 |
Lift coefficient in Eulerian multiphase model | hennas | FLUENT | 1 | July 4, 2011 16:50 |
Zero Coefficient of Lift Problem | MH | FLUENT | 0 | February 25, 2007 11:48 |
