June 11, 2015, 06:42 |
surface injection
Rep Power: 11 |
Hello everyone.
I am trying to inject n-heptane to cylinder filled with air. I am using surface injection. Diameter of the surface is 0.3 mm. The time of injection is 2 ms. And the total mass of n-heptane that should be injected is 0.0306 g. Density of n-heptan is 684 kg/m3. First I calculated total flow rate as 0.0306g/2ms = 0,015kg/s Then velocity magnitude using: total flow rate = n-heptan density * surface area * velocity magnitude. Is this correct because v=300 m/s? My surface has 57 cells so in one time step 57 particles will be injected. Diameter of particle is 1e-5 m. Let's say that Start and stop time of injection is 0 and 0.002 s (injection duration 2 ms) and time step size = 0.0001. So what will be mass injected in one step size (0.0001s) ? - 57* particle volume * n-heptane density? or it depends on total flow or step size ? Do I have to select "Scale flow rate by face area" ? Thank you all for help. Maciej Last edited by maczaj; June 11, 2015 at 08:04. |
parameters, surface injection |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
[ICEM] How to build the mesh for 3 injection area within one surface? | Ryan_Yang | ANSYS Meshing & Geometry | 11 | April 8, 2012 15:20 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 02:10 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 07:47 |
