June 10, 2015, 02:55 |
Broken velocity countours in symmetry plane
Rep Power: 11 |
Hello, this is my first post here.
I'm starting out in FLUENT with the classic Ahmed body exercise. I've done the geometry, a refined hybrid mesh, and got a solution. But when plotting velocity countours in the symmetry plane through the Ahmed body, I get strange artifacts, as if the fluid is somehow broken within the plane. (see attached 'artifacts.jpg'). It only happens for velocity, pressure contours look unbroken. When I repeated using a simple, coarse mesh based only on FLUENT's default settings, the artifacts are not present in the solution. (see attached 'no_artifacts.jpg') But because the mesh is quite coarse, the quality of the results are poor. Why do these artifacts happen? How do they affect the solution? How do I get rid of them? |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Symmetry plane and errors | sherandlock | OpenFOAM | 5 | September 20, 2013 03:03 |
symmetry plane error | antonio | CFX | 5 | May 10, 2012 06:40 |
Symmetry plane error | Luke | CFX | 1 | February 2, 2007 10:35 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
