FATAL: floating point exception (AMG divergence)
Old   June 8, 2015, 23:03
Default FATAL: floating point exception (AMG divergence)
Kegan Leckness
KeganLeckness is on a distinguished road
Hi, all.
I'm running a two-way FSI transient analysis. I have pressure at an inlet defined by a UDF. When the magnitude is 70 kPa, the simulation runs swimmingly; but when I use 100 kPa, Workbench yells about a floating point exception and says 'a solver failure occured during the run in the Structural system'. The structural system, however, points to Fluent which reports
Divergence detected in AMG solver: temperature
Error at Node 0: floating point exception"
Is there any way to work around this? Why does increasing the pressure value only result in some temperature error?
Any advice would be appreciated,
Kegan
KeganLeckness is offline   Reply With Quote
Old   December 2, 2015, 12:10
Kegan Leckness
Before this warning, an increasing number of cells were reported as reaching a temperature limit. I was able to view what cells were problematic by using an IsoSurface in CFD-Post. Changing the fluid domain geometry and initializing a dynamic remeshing scheme solved this problem.
buoyantBoussinesqSimpleFoam: Floating point exception (core dumped) raghav.venky OpenFOAM Running, Solving & CFD 11 June 30, 2019 14:33
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 17:34
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 11:31
Primitive error at node- Floating point exception / continuity divergence issues phales15 FLUENT 0 April 30, 2011 20:05
