How can I set the right Reference Values for airfoil simulation
Old   June 7, 2015, 09:12
Default How can I set the right Reference Values for airfoil simulation
otubaba is on a distinguished road
Hi Guy,
I am running a 2D simulation on a NACA 0018 airfoil (Spalart Allmaras) , and I am having problem setting up the right Reference values to calculate the lift and drag coefficients. So far, my lift coefficient is lower than that of my experiment and other published works.
Here the values from my experimental set up:
Chord=0.25m, Span=0.3m, velocity=15m/s, AoA=10deg, air density=1.16kg/m3, viscosity=1.89541e-5kg/m-s
I'll be very grateful if anyone can help me solve this problem.
Thanks
otubaba is offline   Reply With Quote
Old   June 8, 2015, 15:20
alireza
alireza_b is an unknown quantity at this point
Hi
it is not necessary related to the reference values.
maybe it is from your solver (turbulence models, grid quality, ...)
notice, if your Re # is transitional, you should use transitions models. however
in this situation, you are far from experimental data.
in this paper explain why this phenomena happens.
M. Serdar Gença,, Ünver Kaynakb, Hüseyin Yapici
Performance of transition model for predicting low Re aerofoil flows
without/with single and simultaneous blowing and suction
European Journal of Mechanics B/Fluids 30 (2011) 218–235
but it seems your reference values is correct.
alireza_b is offline   Reply With Quote
Old   June 13, 2015, 18:34
Thanks Alireza
2d simulation, reference values
[ICEM] ICEM Scripting Issues tylerplowright ANSYS Meshing & Geometry 33 September 27, 2021 17:35
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
can not complie fluentDataToFoam in OF2.1.1 hewei OpenFOAM Pre-Processing 20 September 8, 2018 10:19
wmake problems during custom utility compilation palazi88 OpenFOAM Programming & Development 11 August 13, 2018 21:52
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 11:15
