Tips for 3D nozzle analysis
Old   June 4, 2015, 17:07
Default Tips for 3D nozzle analysis
Jacopo
Engineer1 is on a distinguished road
Hello everyone, this is my first post. I am a newbie Fluent user, I just graduated in Master degree in mechanical engineering. Sorry for my English, but I come from Italy.
I have to perform a CFD analysis of a nozzle that will be used as burner in electric arc furnace. The beometry has no axialsymmetry, so I have to do a 3D analysis. The turbulence model that I will use is the k-w sst, that I know is quite fast to get to convergence.
The burner has boundary conditions of inlet pressure and outlet pressure and the fluid is compressible.
I ask you any tips to perform the simulation.
1) For example, I heard that for compressible flow it is good to perform a time dependent simulation to converge earlier, even if I study a stationary phenomenon. Is this true?
2) Is a good thing to put a big volume after the nozzle outlet for the boundary conditions? (because I read often about reverse backflow)
Thanks in advance
Engineer1 is offline   Reply With Quote
Old   June 5, 2015, 03:43
Jacopo
I forgot to say that I'm interested in velocity field and temperature field
3 dimensional, compressible flow, nozzle, turbulence
CD nozzle contour design for 2D analysis rattletop FLUENT 5 January 25, 2011 12:39
Nozzle Analysis Akbar FLUENT 1 March 4, 2010 12:28
Multiphase High pressure nozzle analysis Anant FLUENT 0 December 20, 2005 02:37
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
Analysis of propeller with nozzle Ammu FLUENT 0 July 1, 2005 09:00
