June 3, 2015, 13:46 |
Create Surface in Fluent for DPM
Rep Power: 11 |
Dear all,
Let say I got a square pipe. I am trying to make a surface that is 1/2 the height and full width which means effectively an rectangular shape. But it appears that I created in ICEM and the surface is not shown in the boundary list in the Fluent. Is it impossible to create surface that is half suspended? I plan to release some particle using DPM approach. Thanks Regards, Jee |
June 4, 2015, 05:20 |
Rep Power: 11 |
Hi all,
I think I have solved the problem. I associated the blocks between two surfaces to the plane and the surface appears in Fluent. However, is it worth noting that the surface will be a solid wall which deflect the fluid. Hence, it should be specified with "interior". Hope get it right this time. Cheers, Jee |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] Using Surface Mesh from ANSA for Fluent Sim | tommymoose | ANSYS Meshing & Geometry | 15 | March 3, 2016 17:29 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
create a probe with fluent | Aenseeiht | FLUENT | 3 | April 29, 2010 03:27 |
Fluent Post- Processing: Multiblock surface integral | chinc | FLUENT | 0 | March 19, 2010 21:10 |
