How to control reverse flow and obtain convergence |
S. Morichika
Rep Power: 12 ![]() |
I am running DPM simulation and facing reverse flow in the outlet. I have set the residual convergence criteria as .000001 and solution does not converged. How can I fix the problem? The number of nodes is 400000. I run sever case like 500000, 600000, 700000, 800000, 900000. I checked the mesh quality. The orthogonal quality is .3 and max skewness value is .81. Do you have any suggestion, how can I obtain the convergence. Thanks |
Cees Haringa
Rep Power: 0 ![]() |
In what way is it not converged, can you elaborate a bit?
convergence criteria, reverse flow |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Reverse flow at Outlet | ARUN K RAJ | Main CFD Forum | 4 | March 18, 2015 09:43 |
[How to obtain supersonic flow inside a supersonic wind tunnel ?] | yx213 | Siemens | 1 | September 17, 2014 13:52 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 03:00 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
