Nusselt Number problem
Old   May 23, 2015, 12:06
Default Nusselt Number problem
A7A
AHMAD
A7A is on a distinguished road
I'm working on a convective heat transfer problem.
The task is to calculate Nusselt number in a tube after adding a Twisted Tape. The main problem is that I keep getting a high Nusselt number compared to the experimental results.
Could help me with this problem
Thank you in advance.
A7A is offline   Reply With Quote
Old   May 24, 2015, 13:17
Jim
CFDYourself is on a distinguished road
questions I would ask would be:
1. have you performed a grid independence study ?
2. what type of turbulence model are you using ? are the near-wall conditions appropriate ? are you using a model that resolves the boundary layer directly ?
3. Have you set the boundary conditions appropriately ? if the heat exchange method is through the wall, does your model take into account all of the heat transfer resistances alt can you show on paper that the liquid film is the largest heat transfer resistance in the model ?
CFDYourself is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
How to find Mean Nusselt Number? abhishek4890 FLUENT 4 December 12, 2016 15:15
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
Nusselt Number problem Goutam OpenFOAM Running, Solving & CFD 5 July 12, 2012 06:14
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
