Plasmastream Heating of a Sample
Old   May 21, 2015, 11:55
Post Plasmastream Heating of a Sample
ChristianGermany is on a distinguished road
Hello guys and girls,
I have a problem to which I tried some stuff with Ansys Fluent, but I donīt get it or maybe I have taken the wrong route to it.
This is the problem I am trying to solve in ANSYS Fluent. I have a plasmastream source with a diameter of about 20 mm, at 1 bar and a temperature of 2500 K which streams at a sample holder with about 0,5 kg/s. (For simulation purposes I could assume that it is just air with 2500K) This hits a round cylindrical Sample Holder which consists of a ceramic (0.1 W/mē thermal conductivity) and a sample (10 W/mē) inside the ceramic middle part so that it "sees" the stream. I propably have convection outside of the ceramic, since the stream flows around the sample and heat is radiated from the ceramic and the sample to the outside air at 300K.
If possible, could someone maybe give me some advice on how I could simulate that problem in Fluent or CFX ? Thank you very much !
Best Regards
Christian
ChristianGermany is offline   Reply With Quote
convection, radiation, sample holder, stream of hot air
If a sample line coincides with faces, the user should set the set the sample line?? Hojae OpenFOAM 3 November 29, 2014 06:48
heat conducting in a solid domain Rogerio Fernandes Brito FLUENT 0 March 18, 2008 18:25
heat conducting in a solid domain Rogerio Fernandes Brito Fidelity CFD 0 March 18, 2008 18:24
heat conducting in a solid domain Rogerio Fernandes Brito Phoenics 0 March 18, 2008 18:23
about my old post Rogerio Fernandes Brito CFX 1 February 8, 2008 20:19
