Comparing theoretical calculations with ANSYS Fluent
Old   May 21, 2015, 09:34
Default Comparing theoretical calculations with ANSYS Fluent
Mansoor Ahmed
engrmansoor2534 is on a distinguished road
Send a message via ICQ to engrmansoor2534 Send a message via AIM to engrmansoor2534 Send a message via Yahoo to engrmansoor2534
Hi everyone
I am trying to compare the outlet temperature obtained from ansys fluent simulation and theoretical calculations for 3D laminar, fully developed flow of water in a tube. I have used mass flow inlet and pressure outlet boundary conditions and a constant surface temperature at the wall. I have created a surface monitor at the outlet for mass-weighted average temperature. the results show a deviation of about 20 %. I am using a total inlet temperature of 300 K at inlet boundary in ANSYS Fluent. Outlet temperature obtained from ANSYS Fluent is greater than that obtained theoretically.
Is there a problem in defining the inlet temperature? should a UDF be used to describe the fully developed temperature profile at the inlet?
As in theoretical calculation mean inlet and outlet temperatures are considered.
Your expert opinion is required.
engrmansoor2534 is offline   Reply With Quote
Old   May 24, 2015, 13:26
Jim
CFDYourself is on a distinguished road
questions I would ask would be:
1. have you established grid independence,
2. what about your theoretical caluclations: are you using the same material properties, are you using a correlation for laminar flow etc.
then look at:
how long does the flow take to become an established flow profile - if this is too large a %age of the tube, you can set the inlet profile to be established (this is covered in tutorials from Ansys).
CFDYourself is offline   Reply With Quote
Old   June 23, 2015, 09:53
goku
naruto5255 is on a distinguished road
Check for velocity entry length is matches with the simuation for circular pipe the correlation is 0.05*Re*D. calculate the nusselt number using LMTD method across a section for constant wall temperature the nusselt number is 3.66. 5% error is acceptable .
naruto5255 is offline   Reply With Quote
how to understand UDF in ansys fluent? sriyaz Fluent UDF and Scheme Programming 4 November 10, 2015 03:27
ANSYS and ANSYS Fluent Field85 ANSYS 3 May 17, 2015 17:21
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
export data from fluent to ansys galapago FLUENT 0 August 4, 2010 15:04
Fluent & Ansys FSI architecture help DillonS FLUENT 1 April 7, 2010 17:00
