Mesh is doing some problem
Old   May 21, 2015, 09:01
Question Mesh is doing some problem
Shailesh
prwl120 is on a distinguished road
hey guys
i made a 2d mesh in design modular then make a normal tetragonal mesh. But as i call it to fluent and check the mesh in 2D Space-Planer its says mesh is ok. But on the other hand as i click 2D Space-Axis symmetric it is giving me negative volume. please help.
2D Spacer - Planer :
Domain Extents:
x-coordinate: min (m) = -8.996571e-03, max (m) = 0.000000e+00
y-coordinate: min (m) = -2.000000e-03, max (m) = 5.982000e-03
Volume statistics:
minimum volume (m3): 1.243186e-10
maximum volume (m3): 1.291856e-09
total volume (m3): 3.774166e-05
Face area statistics:
minimum face area (m2): 1.365747e-05
maximum face area (m2): 4.111103e-05
Checking mesh.........................
Done.
2D Spacer - Axis symmetric :
Domain Extents:
Volume statistics:
Warning: non-positive volumes exist.
minimum volume (m3): -1.122491e-11
maximum volume (m3): 4.001538e-11
total volume (m3): 4.688673e-07
minimum 2d volume (m3): 1.243186e-10
maximum 2d volume (m3): 1.291856e-09
WARNING: left-handed faces detected on zone 1: 65937 right-handed, 17976 left-handed.
WARNING: left-handed faces detected on zone 5: 0 right-handed, 10 left-handed.
WARNING: left-handed faces detected on zone 9: 183 right-handed, 67 left-handed.
WARNING: left-handed faces detected on zone 10: 1260 right-handed, 344 left-handed.
Info: Used modified centroid in 33 cell(s) to prevent left-handed faces.
It is recommended that you try to fix the left-handed faces
via the TUI command
/mesh/repair-improve/repair.
WARNING: Invalid axisymmetric mesh with nodes lying below the x-axis.....
WARNING: The mesh contains high aspect ratio quadrilateral,
hexahedral, or polyhedral cells.
The default algorithm used to compute the wall
distance required by the turbulence models might
produce wrong results in these cells.
Please inspect the wall distance by displaying the
contours of the 'Cell Wall Distance' at the
boundaries. If you observe any irregularities we
recommend the use of an alternative algorithm to
correct the wall distance.
Please select /solve/initialize/repair-wall-distance
using the text user interface to switch to the
alternative algorithm.
Done.
WARNING: Mesh check failed.
To get more detailed information about the mesh check failure
increase the mesh check verbosity via the TUI command
/mesh/check-verbosity.
Fluent can also try to fix the mesh check problems via the TUI command
Any possible Suggestion will be appreciated.
prwl120 is offline   Reply With Quote
Old   May 21, 2015, 10:53
pakk will become famous soon enough
Axi-symmetry means that you can rotate your model around an axis.
What would the axis in your case be?
(Your geometry has negative x and positive x, and negative y and positive y. So should can not be around x=0, and also not around y=0.)
pakk is offline   Reply With Quote
Old   May 21, 2015, 15:05
Shailesh
First of all, my geometry didn't have +ve x . And its axis is X = 0;.
Please Help
ansys 14, fluent 14, need help, negative cell volume
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Overset MESH problem DFBI 6DOF Ale85 STAR-CCM+ 0 October 1, 2013 13:25
[ICEM] ICEM Structured Mesh Problem OMJT ANSYS Meshing & Geometry 3 March 22, 2013 11:06
[GAMBIT] SOFC crossflow mesh possible problem??? epc1 ANSYS Meshing & Geometry 1 February 4, 2013 02:57
