How to set up shell conduction?
Old   May 17, 2015, 10:52
Default How to set up shell conduction?
buidu
buidu is on a distinguished road
I am runing a simulation on the convective heat transfer on a cylinder. The cylinder is made of almunium and has a thickness of 30mm. It has a constant inner surface temperature of 40 degree. I want to study heat convection on the outer surface. Can I use shell conduction here? And how should I make the setup? Thank you for your answer.
regards,
Hao
buidu is offline   Reply With Quote
Installation problems indy OpenFOAM Installation 7 April 3, 2009 10:40
Shell Conduction Corentin FLUENT 1 November 12, 2008 06:54
shell conduction @ thin walls Jiri Beran FLUENT 0 May 18, 2008 15:08
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 20:51
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
