Inlet and Outlet Pressure condition for Compressible Flow in FLUENT
Old   May 16, 2015, 23:34
Default Inlet and Outlet Pressure condition for Compressible Flow in FLUENT
rsdsaurav is on a distinguished road
Send a message via Skype™ to rsdsaurav
I am running Compressible flow in Ansys FLUENT. However I am unable to specify the Gauge Total Pressure and Supersonic/Initial Gauge Pressure for the Inlet. For the Outlet I am keeping at normal atmospheric pressure. The flow is taking place in the computational domain where there is static stator and rotor rotating at varying rotational speeds. Current literature says that it is a low Reynolds and Mach number flow. I am getting the same Mach number but my Reynolds number is very low as I am giving 358968Pa for Gauge Total Pressure and Supersonic/Initial Gauge Pressure is kept at 0 atm, which I think is wrong. Can anyone shed light on this issue. Thanks in advance.
rsdsaurav is offline   Reply With Quote
Old   May 17, 2015, 15:19
protocol is on a distinguished road
hi check your outlet condition or give mass flow inlet
protocol is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 13:30
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 10:20
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
