May 10, 2015, 18:15 |
only expert in porous media and fluent
Djilali
hey all Dears, I am simulating a flow and heat transfert in cavity square porous media look at fig 1
Figure 1 Which method suitable for my problem to derive viscous and inertial loss coefficients? 1. Method: Deriving Porous Media Inputs Based on Superficial Velocity, Using a known Pressure Loss. 2.Method: Using the Ergun Equation to Derive Porous Media Inputs for a Packed Bed 3.Method: Using an Empirical Equation to Derive Porous Media Inputs for Turbulent Flow Through a Perforated Plate. second as we know in porous media there are 4 models 1-model of Darcy 2-model of Darcy-Forchheimer 3-model of Darcy-Brinkman 4-model of Darcy-Forchheimer-Brinkman the quastion is how i can use the model of Darcy-Forchheimer-Brinkman in fluent Thanks |
May 21, 2015, 01:06 |
Rep Power: 13 |
Fluent could only support up to Darcy-Forchheimer model. You could need to write an UDF to represent Brinkman term and hook them inside.
July 20, 2015, 15:54 |
mohammadreza
Rep Power: 11 |
Hi every body
I don't know how determine initial velocity for the flow in porous media. Thank you for time and consideration. Best regards |
modeling the fluid flow in porous media by Fluent | Mohsen Nazari | FLUENT | 5 | April 26, 2019 05:45 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 05:09 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 11:34 |
Modeling porous media with FLUENT | newcomer | FLUENT | 4 | September 26, 2013 01:08 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 16:16 |
