Density of a species from PDF table in NON-PREMIXED combustion using UDF
Old   May 8, 2015, 05:50
Default Density of a species from PDF table in NON-PREMIXED combustion using UDF
Baradwaj B S
Bharadwaj B S is on a distinguished road
Dear all,
My name is Bharadwaj B S, I am currently doing a project on biomass gasification. Which I have been doing with non premixed combustion model for flaming mode combustion(combustion of mixture of gases).
I have a sphere inside a fluid domain (cylindrical), from which I have given a mass flow inlet and have assigned the species to evolve from that sphere surface.
QUESTION
I wanted to know whether I can obtain the value of the species which is getting diffused into the fluid flow domain(air)?. In real time using User defined function(UDF) so that I can use the value of density to vary the mass flow rate from the surface of the sphere.
Any help on this regard will be of great use for me.
Thanks in advance,
Bharadwaj B S
Bharadwaj B S is offline   Reply With Quote
Modelling Biomass Combustion via Species Transport Racheal FLUENT 39 January 8, 2022 08:42
Modelling of premixed combustion in a burner rig ThomasS FLUENT 12 September 7, 2018 14:07
Problem with adiabatic PDF combustion SergeyNikolayev Main CFD Forum 0 December 26, 2014 09:28
PB: Saving mass fraction of species on two points with an udf biget.a FLUENT 2 July 23, 2009 04:06
UDF error : DEFINE_PROPERTY with PDF Model Abhilash Chandy FLUENT 0 June 2, 2006 18:07
