May 7, 2015, 18:04 |
Cold Flow on Partially premixed combustion
davuide
Rep Power: 11 |
I have a big problem in the simulation of the cold flow of a Flame D Sandia. If I select only the model: Viscous-KEps (my fluid is only air) the velocity field produced by the simulation is correct; but if I select all the models required for my simulation: Viscous: KEps, Energy:On Radiation:P1 Species: Partially Premixed Combustion-Steady diffusion flamelet and I choose only to solve flow and turbolence equation in order to have the cold flow, the solution is wrong. The difference among the two cases is only that in the first case the fluid is air, in the second case the fluid is the mixture. You can see the different velocity fields (on the left only viscous model, on the right all the required models but only flow and turbolence equation activated) im1.jpg im2.jpg It seems that the fluid can't go out from the inlet! Especially if you look the pilot inlet im3.jpg I hope you can help me to fix my problem. Bye Davide |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
Partially premixed combustion problem | shashankvu | FLUENT | 2 | April 21, 2015 18:45 |
Partially Premixed Combustion not burning | raymond350 | FLUENT | 5 | January 21, 2014 20:28 |
stoichiometry partially premixed combustion | yorelchr | Main CFD Forum | 0 | March 18, 2012 17:41 |
good Cold Flow Results but problem with Hot Flow | Rams | FLUENT | 1 | June 18, 2006 20:59 |
