heat transfer simulation of 3D laminar flow in uniformly heated tube
Old   May 7, 2015, 07:23
Unhappy heat transfer simulation of 3D laminar flow in uniformly heated tube
Mansoor Ahmed
engrmansoor2534 is on a distinguished road
Send a message via ICQ to engrmansoor2534 Send a message via AIM to engrmansoor2534 Send a message via Yahoo to engrmansoor2534
Dear Experts
I am doing a heat transfer simulation in ANSYS Fluent. the case is that water is flowing in a uniformly heated tube. its a 3D laminar flow. the problem i am facing is about the application of correct boundary conditions. the inner wall of the tube is at a constant temperature. the outer wall of the tube is adiabatic. the inlet temperature and velocity of water is known. i want to get the mass weighted outlet temperature of water. the main problem is that if I specify a constant surface temperature at the inner wall of the tube, what conditions should i specify for the water outer surface which is in contact with the inner wall of the tube.
kindly help me in this regard
[attachment:1]water-tube-geometry.png[/attachment]
engrmansoor2534 is offline   Reply With Quote
Question about heat transfer simulation convergence Anna Tian CFX 27 January 13, 2021 15:43
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 05:07
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 16:35
time averaged heat transfer in oscillating flow Matthieu Ubas Main CFD Forum 2 November 5, 1999 15:20
