May 6, 2015, 12:22 |
modelling wall friction
Ronald Thompson
Rep Power: 11 |
im currently trying to model the flow around an object in a tank using the K-epsilon solver, the object is attached to one of the concrete walls of the tank and i want to see what effect the friction of the concrete has on the acceleration of the flow around the object. my question is how do I add in the friction coefficient of the concrete into my model? |
May 6, 2015, 15:56 |
Ethan Doan
Rep Power: 14 |
You should be able to specify a wall roughness in the boundary conditions. You cant use it with enhanced wall functions though. you can use a K-e with standard wall functions or a k-w model
May 6, 2015, 16:17 |
Ronald Thompson
Rep Power: 11 |
do i simply put my value of friction coefficient in for the wall roughness boundary condition or is wall roughness a different scale, thanks
May 6, 2015, 16:53 |
Ethan Doan
Rep Power: 14 |
You cant use the friction coefficient for the wall roughness value you need to specify your wall roughness value in height like millimeters. im not really sure how to take a friction coefficient and turn it into a wall roughness. You could enter various values of wall roughness until your simulation gives you the correct skin friction drag corresponding to your friction coefficient.
April 4, 2016, 05:09 |
Wall roughness height
SRIVATSAN
I found moody chart useful in guessing the wall roughness from the friction coefficient. from the darcy weisbach factor and reynolds number, the chart gives you e/d ratio.
flow around a wall, flow direction, fluent 14.5, friction coefficient, wall friction |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 12:30 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
[mesh manipulation] mergeMeshes problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 3 | July 29, 2015 05:15 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
