May 2, 2015, 06:58 |
Flow in pipe elbow
Martin
Rep Power: 11 |
I have run steady RANS, simulating the flow in fluent in a bent pipe but the velocity does not seem to be right. There should be a secondary motion of the flow due to centrifugal effects and pressure gradient near the wall. So the inlet, which is the top side of the nozzle, should not look like this. I have attached a picture here of the velocity profile. Maybe someone can tell me what is going on. I have used both realizable k-epsilon and SST k-omega, and the result is pretty much the same. The inlet boundary conditions was set as mass flow 0.002 kg/m3 for a quarter model which then was interpolated into this model shown in the picture. This is single flow with diesel as material. velocity.jpg |
May 6, 2015, 16:14 |
Ethan Doan
Rep Power: 14 |
looks ok to me. to see secondary flow better use x y or z velocity ( i cant quite tell where the axis is pointing) instead of magnitude.
May 6, 2015, 16:20 |
Mustafa
Rep Power: 11 |
If the velocity is interpolated then, the inlet should look differently, higher velocity in the core
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 22:25 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 12, 2012 00:18 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 21:41 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 17:41 |
