Stokes' Flow
Old   May 1, 2015, 09:22
Default Stokes' Flow
Ahmed Abdel Samad
3absamad is on a distinguished road
Hello Everyone,
We are trying to simulate a helix shaped swimmer rotating against flow to understand its' propulsion.
Seems to be easy to carry out, however I can't really decide which model should we use since Re<<1.
I've read about the standard k-epsilon (FLUNET help) and it assumes that the flow is fully turbulent, even though the flow in completely laminar and highly viscous (Glycerin) however the rotation of the helix will sure alter the flow wave propagation and the flow won't be laminar around it. What model suits the problem?
3absamad is offline   Reply With Quote
cfd, flunet, stokes flow
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Calculating Stokes number of flow amin.z FLUENT 3 June 5, 2015 04:20
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
