Limited angular rotation of a body
Old   May 1, 2015, 06:52
Default Limited angular rotation of a body
Olivier
orhchand is on a distinguished road
In the frame of a project i am working on, i am trying to simulate in 2D the rotation of the legs during swimming. I am using a very simple model composed of 2 rectangular beams :
- one fixed to simulate the upper part of the body
- one rotating between (-60° ; 60° ) at the tip of the first to simulate the legs
From the research i've been doing, i understood that i should use User Defined Function to make the lower part rotating.
Is there a more simple solution ? If not, could someone explain me how to write
the kind of UDF i need.
Thank you
orhchand is offline   Reply With Quote
fluent, rotation, udf
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
Rigid Body with 3-DOF rotation aeropeng OpenFOAM 3 June 28, 2011 05:43
Rigid body rotation NOT through the CG? Joe FLUENT 6 May 28, 2010 12:03
