Inviscid Solver Convergence (2D supersonic flow)
Old   April 29, 2015, 04:14
Default Inviscid Solver Convergence (2D supersonic flow)
gdbb89 is on a distinguished road
Hey guys!
First time poster here. Have been using FLUENT for a little bit now, so I'm quite new (but determined to learn).
Here's my problem: I'm trying to model supersonic (M = 1.5) flow over a quarterpipe-shaped wedge in 2D. If I take a square geometry and cut out an arc on the bottom right corner, FLUENT is able to solve the problem quite readily. The solution converges in no time, and I'm even able to adapt a mesh refinement where the separated shock is.
Relevant information:
- Density-based
- Energy eqn on, Inviscid solver
- Ideal Gas material
- Pressure farfield set to M = 1.5, gauge pressure 101325 Pa, 300K thermal
- Implicit formulation, Roe-FDS flux type, second-order upwind flow
- Courant number = 5
- Residuals set to 1e-6
- Solution initialized from farfield
This is a simple solution for FLUENT. Here is the refined mesh:
http://i.imgur.com/K7dr9oW.jpg
And a Mach Number contour (from CFD-Post):
http://i.imgur.com/i8tKzUk.jpg
And a plot of my residuals for this case:
http://i.imgur.com/dFySURy.jpg
Now, I'm trying to take this same scenario, except open up my domain in the +Y direction. I want to see the how the shock trails off at the edge. To illustrate, here is my new grid:
http://i.imgur.com/Yz6beIT.jpg
However, when I try to run this, my residuals are completely unstable. Even at a Courant number of 0.5:
http://i.imgur.com/iTNfqse.jpg
I am completely lost as to why FLUENT can't handle this simple doubling of the Y-component domain!
Any and all help is greatly appreciated.
Last edited by gdbb89; April 29, 2015 at 04:15. Reason: Inserted pics, were way too big
gdbb89 is offline   Reply With Quote
Old   April 30, 2015, 13:33
I've tried running this simulation and setting the residuals to 2e-2, the lowest they go before oscillating. This is the result of the Mach number:
http://i.imgur.com/0blxkoE.jpg
It appears as though FLUENT is having difficulting resolving this case for when the shock wave separates from the wedge. Any ideas why? I checked and the first case seems to resolve as the shock wave comes off the edge rather nicely.
Old   March 10, 2016, 09:03
Post Convergence in inviscid flow over a cylinder
mohammad
mmkkeshavarzi is on a distinguished road
Dear all,
I did steady simulation over a body in Inviscid and density based solver,
I monitor the Drag coefficient (Cd) during my Run, it is stabilized after about 2000 iterations and I continue my iterations to 5000 and it is still after 2000.
The Cd value is 0.2 and doesn't reach 0, I assumed that my simulation is converged but know I have doubt about my convergence in inviscid flow.
Is it necessary to reach 0 in inviscid flow for Cd?
and also is it necessary to monitor Cl for inviscid flow?
what is the necessitation to monitor Cl?
Thanks so much in advance for your answers
mmkkeshavarzi is offline   Reply With Quote
Inviscid flow solver luca_g OpenFOAM Running, Solving & CFD 3 August 11, 2024 11:52
Fluent Adjoint Solver Convergence Issue? ex10148 FLUENT 2 July 25, 2016 15:41
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
Jet in Supersonic Crossflow, controlling mass flow rate ChrisA OpenFOAM Running, Solving & CFD 3 November 13, 2012 19:20
Segregated flow solver and no convergence Ankit Purohit Siemens 0 June 15, 2007 10:22
