Vehicle aerodynamics result interpretation
Old   April 29, 2015, 03:49
Default Vehicle aerodynamics result interpretation
daru
daru is on a distinguished road
I have been recently working on vehicle aerodynamics. To start off, I ran an analysis on the Ahmed body and got accurate results.
Having applied the same procedure to more complex geometry (read solar car)
I seem to have gotten erroneous results.
  • Max skewness 0.92
  • Body of influence - one around the car, a finer one in the wake
  • Pressure based steady state solver
  • Energy off, Realizable k-eps, non-eq wall fns
  • Solution method - coupled
  • Under-relaxation factors - default
I used hybrid initialization. Solution converged in under 500 iterations.
The issue is, when I plotted the velocity contours on my symmetry plane I got this (pl. refer velocity_mag.jpg)
So, I wonder what's wrong and how to interpret this result.
Thank you
An inexperienced, undergraduate CFD enthusiast.
daru is offline   Reply With Quote
Old   March 9, 2019, 03:54
Umang Srivastava
umangsrivastava is on a distinguished road
  • Max skewness 0.92
Thank you
Hello Daru,
Seems, you are doing post processing in parallel mode.
Try to do the post processing in serial mode and have a look on plot.
umangsrivastava is offline   Reply With Quote
ahmed body, drag coefficient, results, turbulence, vehicle aerodynamics
[ICEM] Implementing Y+ value in mesh for vehicle aerodynamics Harshal ANSYS Meshing & Geometry 38 August 1, 2014 07:05
The role of CFD in vehicle aerodynamics design and the reasons Anna Tian Main CFD Forum 11 February 4, 2014 05:56
External Vehicle Aerodynamics Torque_Converter CFX 7 October 23, 2013 14:49
[snappyHexMesh] Refinment Level for Vehicle External Aerodynamics danobis OpenFOAM Meshing & Mesh Conversion 0 February 18, 2013 07:37
Expert Systems, the key to vehicle aerodynamics CD adapco Group Marketing Siemens 0 March 19, 2003 10:11
