Turbulent Intesity Inlet and outlet cavitating flow in Nozzle |
April 28, 2015, 13:29 |
Quang Le Dang
Rep Power: 14 |
Dear all,
I have a problem with cavitating flow inside nozzle. I have a convergent-divergent Nozzle with length=600 mm and diameter=50mm, pressure inlet =171000 Pa and outlet=109200 Pa. working fluid is water with temperature =373.3 K. My problem is that I use K-Omega solver and I do not have experience to set Turbulent intensity bcs (both inlet and outlet). Do you have experience about this value (or range of this value). Please let me know. Thanks in advance |
April 29, 2015, 04:54 |
jiri kozak
Rep Power: 13 |
Hello, I'm solving similar case right now. It is C-D nozzle with diameter of 0.053 m on the inlet and 0.02 m in the narrowest part. (2D, axisymmetric, RSM, S-S model of cavitation, transient, BC: Vel. in., pres. out.). My work is focused on the dynamics of the cavitating flow.
I'm not very familiar with K-Omega model of turbulence, but I heard that its implementation in the Fluent isn't the best and realizable k-eps should produce better results (but I'm not sure about that). Anyway there is some calculator for the values you need. You can find it here: http://www.cfd-online.com/Tools/turbulence.php There is some documentation too, so maybe it will be useful for you. If you want to share some experience, please feel free to write me a pm maybe it could be useful for both of us. Good luck and have a nice day |
April 29, 2015, 09:51 |
Quang Le Dang
Rep Power: 14 |
Dear Kozan,
Thank you so much for your help I have realized that we simulate on the same model. However, I try 3D nozzle. I also try 2D and it is very simple to converge. Could you please share with me some information about your input output? of some test cases. I just want to be sure that FLUENT can do this thing. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 07:42 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 07:52 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 02:45 |
