April 27, 2015, 15:24 |
Velocity profile interpolation FLUENT
Mustafa
Rep Power: 11 |
I am trying to simulate a turbulent flow of a quarter straight pipe to obtain a fully developed flow and read this velocity profile to a half bent pipe in ANSYS FLUENT. I hope there is someone who can help me with this problem and I appreciate your time. This is what I have done: I have simulated a quarter pipe and then I have exported the velocity profile and read into a half pipe model. But the velocity profile doesn't seem to be interpolated. I get quite high velocities in all directions and I don't know what the problem is. Maybe the change of geometry have an influence, but then I don't know what to do about it. The velocity profile that was exported from quarter pipe, was read as components in half pipe model as inlet x-velocity, y-velocity etc. I have also exported/read the kinetic turbulent energy and dissipation rate. What do I do to get a proper velocity interpolation? Thank you in advance |
April 27, 2015, 15:37 |
Mustafa
Rep Power: 11 |
I just want to interpolate the velocity profile between the two models. I wrote wrong (not to obtain a full developed flow).
April 27, 2015, 22:16 |
Lucky
Rep Power: 66 |
Make sure you have selected an interpolation method (constant, inverse distance, or least squares). I forget what the default is.
Interpolation is based on all x,y,z coordinates. This can cause problems if you try to map data at say y=0 plane in one simulation onto the y= 1m plane on the other simulation. Even if the x&z coordinates are the same, the interpolation will compute the distance r = sqrt(x^2+y^2+z^2) and the interpolation will look funny. You may want to delete the y-coordinates from the profile file manually to avoid this. Maybe this is your problem. Just a guess. |
April 28, 2015, 04:23 |
Mustafa
Rep Power: 11 |
Thank you for your answer LuckyTran,
I have tried all three interpolation methods, but the result are the same. But how can I delete the y-coordinate from the profile file? I have also tried to only include the x-velocity but nothing interesting happens. |
Drawing a velocity profile as inlet boundary condition in Fluent ANSYS ???? | hasanifte | FLUENT | 2 | February 18, 2015 13:44 |
Fluent does not recognize my UDF for velocity profile | salihovic | Fluent UDF and Scheme Programming | 1 | September 10, 2012 07:27 |
logarithmic velocity profile for velocity inlet in Fluent | amarendernag | FLUENT | 3 | August 25, 2012 06:44 |
Simulation with UDF for species mass fraction and velocity profile | virgy | Fluent UDF and Scheme Programming | 8 | February 7, 2012 05:30 |
Using Line/Rakes as a Velocity Profile in Fluent | JLRC87 | Main CFD Forum | 0 | March 16, 2010 13:21 |
