FLUENT How do you duplicate the command window after a calculation is finished? |
April 27, 2015, 03:05 |
Rep Power: 11 |
When a calculation is being solved the command window shows the residual values for specific equations as well as the time it took to solve the specified iteration. When you close FLUENT after the calculation completes, and reload the solution data, the information shown in the command window is lost. How can you get a copy of the data that is displayed in the command window during the calculation? Thanks in advance.
April 27, 2015, 06:05 |
Rep Power: 18 |
Right click command window > Select All, then right click command window > Copy and then open a text editor and paste (shortcut: Ctrl + V).
April 27, 2015, 22:09 |
Lucky
Rep Power: 66 |
I don't know how to load the output after the fact, but you can specify extra options for fluent to save the output to a text file.
June 5, 2015, 22:29 |
Rep Power: 11 |
How do I access and save the residual history to a data file after FLUENT has been closed? Thank You in advance.
June 8, 2015, 11:55 |
Andrew Kokemoor
Rep Power: 14 |
If you use Workbench, it will automatically create "Solution.trn", a transcript of the command window. Section 3.11 of the Fluent User's Guide discusses how to create your own transcripts. I'm not sure if there's a convenient way to get residual data, but if it prints to the command window, you can pull it out of your transcript.
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 10:07 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 11:54 |
Wake Length calculation in FLUENT | mahi007 | FLUENT | 2 | March 14, 2012 05:51 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
[Commercial meshers] Converting meshes that includes interfaces | ham | OpenFOAM Meshing & Mesh Conversion | 29 | January 8, 2007 09:58 |
