April 19, 2015, 22:46 |
fluent error: absolute pressure limited to 1
Yicong Cong
I am a learner of Fluent. I encounter a problem and cannot handle it. Please help me. I am dealing with a blast wave problem, but error occurs during calculation. absolute pressure limited to 1 temperature limited to 1 absolute pressure limited to 5e+10 temperature limited to 5e+6 ( I have increased the upper limit) My domian is a 1/8 sphere. I set operating pessure to 0, so all pressures in inlet and outlet are absolute pressures. The inlet is the small spheric surface and the type is pressure-inlet. Profile is used to input the pressure history. Outlet is the big spheric surface with gauge pressure to be 101325. I initialize the solver by hand with 101325pa in the domain. Material is ideal gas. Model settings are inviscid and energy on. Sovler is density-based, explicit, first upwind. Time step is 1e-6s. And the grid is smoothed over 0.5 for orthogonal quality. I have no idea why this error arise. Please help me. Many thanks! |
April 24, 2015, 00:50 |
Still in trouble
#2 | |
Yicong Cong
I used contour to find out in which area the temperature is limited to 1.
And I found that it's the cells just close to the centre of the pressure-inlet. I checked the profile I input and cannot find any error in it. Do anyone know what's going wrong with my case? Hope someone could help me. OTZ Quote:
November 20, 2015, 05:39 |
Arif Shafiq
Rep Power: 12 |
have you solve this problem ??
November 20, 2015, 09:18 |
Rep Power: 27 |
This only shows that the simulation diverged. It can have many different reasons, and the reason for treeman1 is probably not the same as for you.
In my experience, mostly it is a bad mesh that causes divergence, so that is the first thing I would look at. (Examine the mesh in the region where you see extremely high/low values in your solution). But like I said, it can have many different reasons. |
November 20, 2015, 10:20 |
Lucky
Rep Power: 66 |
Has anyone tried laminar w/ energy to see if it still diverges? It might be a problem with the inviscid solver.
error, fluent |
Fluent Pressure outlet b.c. | beanlee999 | FLUENT | 14 | August 3, 2021 19:52 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 12:35 |
How to give pressure inlet in Fluent | Vijayaragavan | Main CFD Forum | 1 | December 17, 2007 10:40 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 12:26 |
absolute pressure limited | Boisson | FLUENT | 1 | December 9, 2001 14:21 |
