Unsteady Simulation, Cm and Cd values are varying with time step |
April 17, 2015, 16:11 |
Siva
Hi All,
I have a case with a bluff body inside of a wind tunnel. I am running this as an unsteady simulation. I am using the Detached Eddy Simulation model with K-W-SST. The boundary conditions are walls for the body and the walls of the wind tunnel. Inlet is a pressure inlet and outlet is a pressure outlet. The outlet pressure and the operating conditions are both 0 pa. I am trying to recreate simulations run on a different solver, so I know the correct Cd and Cm I am setting up the lift monitor with these commands, the first 1 being a wall-id. set-drag-monitor yes 1 yes yes "cdOut" yes 1 0 0 monitor-unsteady yes The result I am getting is that the Cl and Cd values are converging within about 400 iterations, instead of fluctuating with the vortices that should be forming. I have run till 30,000 iterations and there is no fluctuations that are occuring. (there are 35 sub iterations for every time step) Also, as the time step is decreasing in size the Cd values are increasing by an order of magitude (0.1 s -> 1 Cd, 0.001 ->10 Cd , 0.0001 -> 100 Cd) Any pointers at what could be wrong or what else I could look at? Thanks y'all! This is my input commands: /file/read-case CASE_NAME mesh check q q define boundary-conditions modify-zones zone-type wall-3 pressure-outlet zone-type wall-2 pressure-inlet q pressure-inlet 149.958 q operating-conditions operating-pressure 0 q q define models viscous detached-eddy-simulation yes sst-k-omega q unsteady-2nd-order-bounded yes q q solve monitors residual convergence 0.0000001 0.0000001 0.0000001 0.0000001 0.0000001 0.0000001 n-save 10000000 plot yes yes q q init set-defaults k 0.00104 omega 7830 x-velocity 15.6464 q init q set max-iterations-per-time 35 reporting 1 number-of-time-steps 10000 time-step 0.107 data-sampling yes 1 yes yes q initialize init ok q set /file/write-case-data CASE_OUTPUT_FILENAME q q report reference-values area 0.034403157 length 0.23368 pressure 149.958 velocity 15.6464 viscosity 0.0000181205 temperature 288.15 density 1.2251 q system proc-stats sys-stats q q file auto-save append-file-name-with time-step 6 data-frequency 10 case-frequency if-case q q 1 solve monitors force set-drag yes 1 yes yes "cdOut" yes 1 0 0 set-moment yes 1 yes yes "cmOut" yes 0 0 0 0 0 1 set-lift-monitor yes 1 yes yes "clOut" yes 0 0 1 monitor-unsteady yes list-monitors /solve iterate 1000 /file/write-case-data OUTPUT_FILENAME /exit yes Last edited by smnitro; April 17, 2015 at 16:15. Reason: Adding more information |
